bwdbrn1
- Nov 23, 2011
- 383
Fortunately no, I haven't broken any, but in hind sight and from what I've been told by an experienced Jake mechanic, I consider myself lucky that I haven't. I suppose I could have mentioned the advise I'd gotten from the mechanic earlier. Like you said in an earlier post, it looks like it could be tapped and threaded, and I did do just that with the first one of mine I did. I got it off, but can say first hand looking back that it was much more of a struggle to do than the method outlined in the manual, and through conversations with that Jake mechanic on another forum, (Smokstak) I was told that I had been very lucky I hadn't broken anything and also told by him not to pry on them. Like snowy weather noted, there is very little gap between the flywheel and the block, additionally, that "flange", for lack of a better name right now,around the outside of the flywheel is fairly thin and has a lip on it. That flange would be much easier to break than the flywheel.
