I'd say that the oil seal under the flywheel is the cause. Remove the flywheel and you should be able to see where it is coming from.
Not too bad of a seal to replace. I drill a couple of small holes in the seal and install a sheet metal screw in the seal to pull the old seal out. Then just tap the new one in.
Round, about one inch in diameter.
Thank you..is the seal round or square?
When you said square seal that is just something I just couldn't picture in my mine. The only thing I really could think maybe gasket or a square ring seal. The seal we are talking about is a round lip style seal that seals the case to the crankshaft that spins. Marion NY as a small town about 20 miles east of Rochester NY. Isn't Kingston in the south eastern part of the state or are you talking about Kingston Canada which I live about a 100 miles from?
Yea after I saw the part list I saw it was round..now it shows a round gasket too..would you think that would need replacing? Is that hard to do? Do you need special tools to do it?
I was thinking of Mt. Marion..I live there for about 5-6 months..it's just north of Kingston NY...
