reynoldston
And gas only sat in that carburetor for 30 days :thumbsup:
I dont know how long sat gas in that carb. The engine was full of water up through the breather where air filter sits, air filter/air filter cover missing, wrong bowl on carb, missing primer bulb, and mower was sitting outside.
Now that I can believe. Your ultrasonic sure did a nice job. I could never get a carburetor that bad that clean with my chemical cleaner.
Funny my father in law does this when he has a battery go bad he drains it into this giant cast steel pot in his shop and he cleans all sorts of metal stuff
Here's pic of the mower that it was on. John Deere walk behind. I had to change the oil twice to get all water out. Both times the oil was changed while still hot.
I had a neighbor with a mower that looks just like the one in your picture. He wanted me to get it running for him. What he did was run it out of oil and did a lot of engine damage to the point that when I put oil in it ran right out the bottom of the engine. He now has it for sale and asking 40 dollars for it. Would that mower be worth a engine if I bought it from him? It still looks almost like a new mower yet.
If all it needs is new rings, oil seals, and maybe new piston then Id buy it for $40 fix it then resell it for $150 not self propelled or $200 self propelled in the spring. The one in my pic isnt self propelled so it will be priced at $150 come spring.
That would mean a no seeing I really don't think I could fix it for 160 dollars plus I would want to make money on the deal. It needs a engine because the engine case is bad. Also running it out of oil I would think the cylinder walls would be scored?
OK. Probably looking $300-400 in shortblock or complete engine then. If it was me I'd gamble on it then part it out on ebay and other site.
