Carscw
Thanks for the link. I tried your test of turning the key on and pulling the pto switch and I could not hear the clutch try to engage. Does this mean bad switch? I checked voltage where the wires hook to the clutch and they seem to be putting out proper voltage when the pto switch is engaged or disengaged.
I would think if your getting power to the clutch when you pull out the switch then the switch is good. I am thinking the clutch has gone out.
There are a few guys on here that know more about how the clutch works. I would wait and see what they have to say.
So my best advice is let's see what others have to say.
