basketballmate
- Nov 5, 2013
- 9
Hi guys, I am from New Zealand and i have owned a honda hru216d lawnmower for 2 years. JUst recently mower started having problem with mulching, it does not mulch grass into fine pieces as it used to, blades start strugling even with short grass, sometime blades disk just sink into ground and leave a unpleasant mark. lawns looks really bad after cutting.
I have checked air filter and spark plug and have replaced new blades, and set RPM to 3500 and it still cuts bad. I took mower to a mechanic and he said mower is phisically OK, not problem was found.
What i noticed is the mower started cutting bad problem since last time i replaced blades in a local mower shop. So i was wondering if there is a possiblity the mower shop had done some tricks to my mower, causing now its irregular and bad cutting.
Anyone knows whats going on with my mower? I would really appreciate your suggetion.:laughing:
Regards,
Steven
Regards,
Steven
