Carscw
- Aug 11, 2011
- 6,375
you could have gone to most any repair shop and got one todayYeah I ordered one from the manufacturer.
Kinda hope the OP has resolved this by now since it has been nearly 9 yrs since his last post.Check the "LEAN" of the pully support posts, to see if they have bent over time. If they are off-angle, that will shorten the distance the belt is supposed to travel causing slack. Also, makes the pulley operate at an angle to dump the belt off of them.
