exotion
Turns Freely with indications of compression (per my neighbor) Let's see what tomorrow brings!![]()
Well if it spins its worth fixing
After the engine start on the rest of the machine
Go here to Briggs shop and part manuals. Lawn Mower Parts & Small Engine Parts by Briggs & Stratton. If its seized pulled spark plug. Then fill cylinder with mystery oil. Thats known to free engines up.
Well if it spins its worth fixingtest for spark, test compression, clean or rebuild carb, adjust valves and clean with a tooth brush. When you get it running I would pour a little seafoam in the spark plug hole put plug in start it up and watch it smoke and clean
