yvescastonguay
- Aug 17, 2013
- 13
Trying to ressucitate an old Toro. Need to find model number in order to get parts. Starter recoil shroud has VMK9 202912. I think it relates to the engine being a Suzuki. Carb is a Mikuni with inscriptions:87C10 N 957. Engine is also stamped 87CI above valve chamber. Engine is OHV. Mower has 3 speed tx. Only second speed working for now. Body is magnesium or aluminum. Air filter box is opening from the top. Width of cut is 53cm, per sticker on body. Handlebar has a part number: 66-0260. Needs a dipstick, some tx adjustment, carb and valves adjustment, and she'll be ready to go. Your help will be appreciated.
