Brucebotti
- Jun 9, 2011
- 297
You guys are funny, :biggrin:
Now I'm not trying to be an azz here but , So you found out the hard way gator blades don't like wet grass. I find that statement pretty ironic when you consider your always cutting wet grass. As far as finding it strange that the only clumps of cut grass you get is whenever you cross over the driveway, it would be strange if if didn't when you consider the way a gator blade works, I mean as soon as you hit the drive the blades have nothing more to cut or throw to the top of the deck to be re-cut so naturally the grass that's in the deck will be discharged. :smile:
Ric,
No problem.....I'm here to learn...:smile:
Bruce
