seagiant
- Aug 3, 2013
- Threads
- 25
- 128
Hi,
I came into 2 Echo string trimmers and decided to do a basic rebuild. The first was a SRM-140 curved pole trimmer. Rebuilt carb with kit. New fuel line w/filter. New spark plug. Trimmer started right up after rebuild tuned it and it is good to go.
Next trimmer is a SRM-200 DA straight pole model. Did the same thing with it on the rebuild and can not get it to even fire! I have good spark at plug,carb is getting gas,muffler is clean. Checked compression and it is at 65 PSI but so is the other one? I've looked at the piston and it looks good? I have run out of things to try? Was wondering if anyone has any ideas? Thanks!
