Winter Tinkering
KennyV
The most "expensive" maintenance procedure I have is changing the hydraulic fluids on the zero turn and tractor.
I
Travis, if I had that synthetic mobil1 you drain from your hydraulic system... I would filter it and blend with my diesel fuel...
You are right about DIY it gets things done right and is very satisfying ... :smile:KennyV
Muhammad
Administrator
Staff member
Hey Kenny, how old does the Mobil1 have to be before you wouldn't want it anymore? How much do you blend?
KennyV
You can mix up to 50/50, The age is not so important. Oil used in a hydraulic system generally breaks down in viscosity over time. That makes very little difference using it for fuel. Just needs to be uncontaminated and relatively clean...
:smile:KennyV
noma
Hi all
I do some of my maintenance in the fall like change the engine oil and add stable to the gas, i do this because i don't like to leave that contaminated oil in the crank case all winter so i get it out of there as soon as possible when it's warmed up and done mowing for the season. I live in in the country and i don't want to load that mower up every time it need simple maintenance work needs done i have a 48'' rider.:licking:
Travis_R
Actually Kenny, I use Amsoil Synthetics in everything I own. I use some of the old oil to put under my mower deck and Bush Hog. I wash out and clean from under the decks, let them dry and apply the oil with a brush. Keeps from rusting out...:thumbsup:
Every couple tanks of fuel in my tractor, since it's diesel, I add a quart of Dexron III automatic transmission fluid to a full tank. It keeps the injectors clean.:thumbsup:
KennyV
A
Anything helps.. but with the ultra low sulfur diesel you need to add a bit of lube to the diesel...
Sulfur use to be the high pressure lube in the injector pump... Testing has shown that as little as 2 percent bio-diesel, is the best diesel additive you can get for the injector pumps... :smile:KennyV
