kmvorndran
- Jul 20, 2013
- 2
My smartdrive on Honda HRR2168vka was not working. I noticed that there was some grass clippings stuck on the pulley system and the belt actually came off. In attempt to get the belt back on, I mistakenly removed the cover for what I believe is the transmission on the smart drive. As I removed the bolts, a type of oil leaked out. Since then I have found the correct way to fix the belt. However, I have been unable to determine what type of fluid this is to put the cover back up in sealed fashion. Anyone know if this is just regular oil, and if so what weight or some type of transmission fluid? Or if Honda has a special Honda brand fluid that must be used?
Thx
Thx
