Thanks, Bruce. That's what I was thinking. I only have somewhere around 3/4 to 1 acre to mow so I think the Titan may be overkill.
Does the MX5060 handle slopes well? My yard is sloped away from my house maybe about 10 degrees or so, sightly more in limited areas.
I just saw this review on the Home Depot site and thought it may help answer your slope question:
"I have 5 acres of hilly (10-15 degree slopes) terrain with lots of trees, and this Toro is powerful and maneuverable enough to give me no problems. I've only had this one month, but I'm absolutely happy with this purchase after having used it twice now.
At first, I didn't think the speed control was too big of a deal, but now I'm very glad for it, since most of my 5 acres is a bumpy ride. Being able to select the slower speed greatly helps me protect my mower from me (i.e., going too fast over the numerous "potholes" in my lawn and bouncing too hard).
Love the powerful deck (welded, too!). I had some grass I had totally ignored for about a year, and so it was literally over 3 feet tall. Went over it no problem with this Toro. Branches, small bush weeds, etc., all were chopped up as if they were grass.
Looked at several different zero turn mowers, such as John Deere, Simplicity, Husq, etc. Went with Toro because:
1) Kawasaki engine is top of the class
2) Reliable name brand
3) Welded deck
4) Big rear tires (helps with traction on my hilly terrain)
5) Powerful (again, helps with my hilly terrain)
6) Shipping was super easy (don't need a forklift of chainsaw to haul around and cut open a mammoth crate. Toro delivered to my garage, rode it down, and went over operations and maintenance for me. Couldn't be better!)
7) Numerous Toro service centers around where I live
8) Easy to maintain myself
9) Foot pedal for deck height adjustment
10) Easy to clean (garden hose attachment for deck)
The only thing I wish this mower had was more accessory options, like the roll over bar (Toro said those bars are only on their commercial models). However, not too big of a deal, even on my steep slopes, because the rear tires are huge, and you sit basically right between them, giving you good balance. I just go parallel up and down my hills, and the big tires and powerful motor make the pieces of cake to mow.
Well-designed model gives easy access to battery (just lift up seat), engine, and other components for quick maintenance. Air filter is right in the back, so you don't have to squirm your hand around to replace it (as you do have to in some John Deere models I looked at).
Definitely recommend this mower if you have a large area that's hilly, bumpy, and treed. Well, I guess I recommend it even if you have a small and flat area!"
