Welch plug removal / install
Tap the center of the new plug with a hammer and punch and it will expand. Just don't get too strong with the hammer.
I removed the old plugs and installed new ones (2) thanks. The internal passage was very dirty. Now to install and see if it leaks!
LB
LB
No leaks. Still will not adjust. surges, high RPMs, no idle. same old ****.
I still think it is the wrong carb. that came on it. The 632991 is correct
I think, but not what is on it.
