Things to look for when buying a used mower
I saw this on another forum and thought everyone should see it.
"Buying used outdoor power equipment can be a great way to save money but it can also open a can of worms and end up costing if repairs are needed. How do you know if a used lawn mower is going to be a good deal? That's what one of our forum members asked when he wrote no the Gopher Lawn Care Business Forum "I have found a deal on a 2007 ExMark LZ25KC604 60″ with 25 HP Kohler with 240 Hours. I have been offered this for $3000.00. It appears to be in great shape.
This is my first zero turn and I have been looking at Scags and Exmarks. What should I look for before I decide? I think this is a good deal. Any comments or suggestions appreciated."
Thankfully another one of our forum members is a outdoor power equipment dealer and he knows his stuff. This is what Eli shared with us and it will help all of us when we are looking at used outdoor power equipment. He responded "First, are you buying this from a Dealer or from an individual? If from a dealer, will they give you any warranty? Since you have been looking at new mowers of the same brand, how much would a similar one cost you new? Assuming it has no warranty and passes the test as follows below, I would pay no more than about 60-70% of new price similar piece of equipment. Do you know if $3000 is the lowest price you can get on it? Have you tried to get a lower price?"
Here are some questions I am sure you already know the answers to, but for everyone's benefit I will post the questions anyway.
1. If you are buying from an individual, why are they selling it?
2. Was it used to mow their own yard only? or was it used for commercial use (to mow more than their own lawn).
3. Can you verify their answer to #2 without asking them directly or even indicating you are questioning their answer (no longer need this big of a mower? or decided to get out of the lawn care business? or?. Just think, does their answer make sense???
4. Do they have maintenance records? Will they provide these records to you to preview before the purchase? Will they provide these records to you with the purchase?
5. Can they tell you who serviced the equipment when it was serviced? Can you verify this?
6. If buying from a dealer, have they serviced the mower including sharpen the blades, check the belts, change spark plugs, Air Filter, Fuel Filter, and oil?
7. Have they ever serviced this mower before buying it?
8. Did they sell the mower new?
9. Why did the original owners sell it? (Again, think about their answer to see if it makes sense or not. Typically power equipment dealers are considerably more honest than car dealers but there are a few here and there that may still lie to you?)
10. Do they know if the owners were the caring type?
11. How does this mower compare in price to other mowers the Dealer is selling?
12. Will the dealer show you or tell you what the blue book value is for the mower?
13. Does the mower have an hour meter on it so you know it only has 240 hours on it or is this a "guesstimation"? (This applies to both Dealers and individuals)
Either way, look for these signs of wear, abuse or lack of maintenance:
A. What is the over all appearance of the mower (look for chipped paint, bent parts, etc.)?
B. Do the tires have any signs of being plugged?
C. Do the tires appear to have lots of wear?
D. Remove the dipstick to see what the oil looks like (look for black oil, is there enough oil, etc)? If you don't know what black oil looks like, pull the oil dipstick out of your car when it reaches 3000 miles after an oil change. Or, take a mechanic friend with you to look at the mower.
E. Check for loose parts (loose or missing bolts). This is a good indication this mower has been taken apart in the past or that the owner has been abusive with the mower/engine.
F. **Caution, it is recommended that you wear gloves while doing this part of the check up. Also remove the Ignition Key to prevent anyone from trying to start it while you are doing this.** Reach under the mower deck and grab a blade. Now try to move it up and down, checking for deck bearing wear. Also check for blade sharpness, dings to the blade's cutting edge, bent blades, and large deposits of grass underneath the deck."
(Warning: read this before you buy a used mower. | Lawn Care Business Marketing Tips - GopherHaul Blog)
Mad Mackie
Good stuff, but not many perspective buyers will do the entire list and sometimes sellers won't let you do this list.
Had a friend that was hot for an Onan powered Ingersoll 4016 from a private party. Big dollar package, seller agreed to let me check it out and do some diagnostic testing on the Onan. Did a leakdown test on the engine, found the Onan to have some serious blowby. Seller got angry with me and told both of us to leave his property NOW!!! As we were leaving I noticed an oil soaked Onan air filter in the trash that was out for pickup. Saved my friend a lot of money!!
Several years later I ended up with this machine in my shop for repower to a Briggs Vanguard 18 for the same guy that had told me to leave his property!!! Go figure!!!!
Mad Mackie in CT
Ric
Great check list. The thing to remember though, is even with doing or using that or your list to buy a used mower or new mower for that fact is there are no guarantees either way.
Bill Martin
Loose spindles and banged up deck. Mowers shouldn't look like a wrecked NASCAR! Check hill power for transmission issues
sjessen
If it is a local mower it is worth trying to find out where the owner has service/repair work done. Oftentimes, a dealer has good insight into how the equipment has been treated i.e, did they fix things as soon as they broke or did they just try to keep the mower running with the least amount of maintenance possible.
Darryl G
Consumer Reports is not what it used to be. Their business practices are terrible and their reviews questionable as far as being impartial and unbiased. You're better off asking your next door neighbor's brother-in-law!
willys55
You left out 14)Where to put it so the wife no see it, because you have 5 or 6 already
EXACTLY!!
alomo
