Hello. I am trying to remove the roto-stop assembly to check it because the roto-stop cable got damaged (see my other thread about the recall work:http://www.lawnmowerforum.com/honda...-older-honda-recall-notices-2.html#post113251). It seems the dealer over-tightened the crankshaft bolt because I am having a hard time removing it. I tried holding the flywheel bolt (that loosened first) and using a strap wrench around the flywheel to hold the crankshaft still. I have heard about putting a rope into the cylinder via the spark plug hole, but I am afraid of bending the valves or breaking something. Any other ideas?
