lawn mower fanatic
- Jun 8, 2012
- Threads
- 321
- 6,749
The new Honda mowers have something called the CLIP DIRECTOR, where you can change the setting of the mower from mulching to bagging using a lever. I had mine on mulching, which closes this door so no grass is SUPPOSED to go past the plug, but as you can see, it does not work. Honda needs to improve the seal so this doesn't happen! The attached picture shows how much grass got past the "door" and was just sitting in the space in between the door and the other door (for lack of a better term) that you put up to fit the bag under if you want to bag.
