kneehighgrass2013
I have no spark on my craftsmen 12hp mower. Plug is good wire to plug is good and so is the ground. Is there a way to check the coil? Should I just get a new one or should I pull the fly wheel and clean the points?
What are the model/type codes on the engine?
Unless it's about 30 years old it does not have points.
If you disconnect the kill wire from the coil it will isolate the coil. If it doesn't get spark with the wire disconnected, the coil is bad.
Is this the small black wire coming off the coil to a bolt/ground? If so I have tried that with no success.
