I had purchased a used Bad Boy 60" deck mower from the original owner. I currently need to replace the blades and the blade number calls for 38-6060-00. I purchased some aftermarket blades for it and installed the blades but the blades hit. The blades measure 20 1/2" The original blades that are on it are from the factory stated by the previous owner and also stated he has never replaced them. The blades on it are 20". All the blades i have researched for a 60" deck says they should be 20 1/2.   The cut with the original 20" blades seem to leave a stripe when cutting.
Has anyone found this problem? Thank you
