Take off the valve cover and check the valve clearances. It may not be a valve clearance problem as much as a bent push rod, and possible moved valve guide, causing the bent push rod. Just something to check, may not be the cause.
I just checked and I do have spark. So the motor turns over and I do have spark but it won't start.
