Ric
I dont have a Ex Mark, I have a JD LT 445 w/ 60 in. cut, i mow close to 4 ac. with it, the blades are heavy/thick Blades, i sharpen them about after ever 3 or 4 times of mowing, I replace them when the blades are getting to the point that I think they should be replaced, I get about a year and half out of a set of blades, i use a 4 1/2 in. side grinder to sharpen my blades, I put the blade in a vice to hold it while i sharpen it, i check the balance on them by putting it on a Nail that is driven in the wall, i dont very often fine one that needs to be fixed, blades ware even, not a big deal to me
One of the biggest problems i fine with oweners of Mowers, is they dont keep the Blades sharp, a mower runs so much better with sharp blades, when i was younger I helped with a Yard Mowing Crew, the big mower was going all day, we had 2 sets of blades, & most of the time we put on a sharp set of blades not long after lunch, you could tell it when the sharp set went on,
You check the blade balance by putting it on a Nail that is driven in the wall? You do know in order to balance a mower blade you have to find the center of rotation, you can't do that by using a nail. Using a nail is a myth and besides that you can't put the blade back on the nail in the same place twice.
