OK finally made some serious headway with this thing.  Had to lay off it for a bit.  Neighbor had a oak tree split and I got some free firewood for next year.:wink:
I do NOT pass on free oak.
I finally decided to pull the carb, and went through it.  Then re-installed and adjusted according to the owners manual it came with.  Adjusted the idle mixture and idle speed, then adjusted the high speed mixture.  Revs freely all the way to governor cut-out.  Very happy with performance.  I also finally got the breaks working.  Took a new master cylinder.  There is still a little bit of air in the line, kinda frustrating, but the parts guy in Michigan said they can be a real bear to get all the air out.
He pumps it in from the bottom up, which I did, but still got bubbles in there, darn it.
I also got the electrical all figured out, including a break pressure switch to activate the brake light.  Got the headligh working, but had to make a switch for the handlebar.  Most all are made for 7/8 bars, and these are 1".  Most were also too expensive or had all sorts of extra switches, like horn, kill button etc.  I have the bed installed again.  All I need to do now is remount the seat and seat back, that have re-upholstered.
I will post pics as soon as it's all back together.  Very close now.  Thanks for the support here.
