ZTX Deck Level ?
Already have that. Need procedure. There’s two adjustments on each side but none in the front to raise or lower. Side adjustments seem to contradict each other.
The manual is just a guide.
Do you know how to work the leveling bolts? If so, move on to getting it leveled. Park it on flat of level ground. A concrete pad works best
Here is an Ariens video. The concept is similar.
We don't even know what kind or exact model of your Cub Cadet is. You need to be more specific.
The manual shows 4 leveling bolts. Two on each side by rear wheels and two on each side up front near the frame.
That’s what threw me off. Couldn’t quite grasp level side to side and then front to back. Video made more sense. He adjusted front to back on each side. No side to side. If the blades are equal front to back side to side should be.
I like to cheat a little during the initial leveling. I use two levels.
