ZT52HD DECK VIBRATION FIX
I feel this is not normal for the deck belts to dance and wobble like they do on this Apex I have. Whoever designed this machine perhaps was not on top of his game. I doubt that these mower makers have top engineers designing these units. Top guys are too expensive. What's really disappointing is that they go ahead and market these mowers the way they are.
And how many consumers will notice? How many will complain? It's a game for them, and they win. Odds are most will not take note. And when the dealer and maker says its normal, what can we as consumers do? My dealer told me they have had no complaints about this belt issue. He's a large dealer, sells many mowers each year.
What would you think if you opened the hood of your new car or truck with 20 miles on it and saw the belt dancing, wobbling like it does on these mower decks? Then, the dealer said that's normal. Just because this is a lawn mower doesn't mean it shouldn't be made to perform properly.
My question is to anyone who is reading this thread to tell us if they know anyone who owns or has owned a Gravely or Ariens for several years with this issue. What has been the history of belt replacement, bearing replacement on the deck with that machine? How many hours on the machine before a belt or bearing failed? This Apex I purchased is a commercial unit. It's made to mow bunches each summer. I live on a acreage and mow a little over an hour each time. Light use for this type of machine. But, I wanted a quality machine. I am very happy with the cut. Lawn looks great after I get done.
I plan on looking at other machines to see if their deck belt dances, and wobbles like these do. The solution could be something as simple as spring tension. If we all would have tried our machines out at home, then told the dealers to fix this issue or I am not interested in this mower....it would have been resolved. Funny when something is paid in full, they don't want to be as helpful anymore.
My ZT HD 48 bought new in 2017, now has 225 hours.
Currently have three new spindles coming in this week. Anyone operating equipment knows we get a 'feel' for what we consider normal.
The deck began vibrating and buzzing worse than before. Removed belts, used impact gun and spun the spindles up, made a rough noise.
Not totally dry but upon removal can feel they are or will soon be a 'suddenly' issue.
I spray belts with 303 yearly and they do look good. Any benefit of a kevlar belts??? I'm open to this.
Now the spindles wow another story and will not alter the thread by delving into it.
So having read all the comments, upon installing the new spindles will ponder the enhancements.
Like the fuel hose on the guide bolts and the spring mount bolts.
I installed nylon washers under the deck hanger bolts. That did help reduce the buzz quite a bit.
Don't know if this helps anyone but it's my feed back.
I'd kinda like to hear the story with the spindles.
Well Gravely in this model. the blade hub does not have the two holes drilled out that allow a spanner wrench. And a torch needs to be used to melt the red loctite. Only propane on hand and did not work.
Lonnie Johnson has an old video on how to disassemble this particular spindle and did a nice job explaining the details. Spindle rebuild
News ones from IGOPRO LAWN SUPPLY on the way, are also cast iron. Visited a fab shop and told me he had no torches.
if I go to a local welding shop they are about 95 an hour. For them to heat up and remove blade hub on three would be about 60 percent of three new ones.
I old and cheap and it just irritates me not having a easy peasy time.
Later I plan on using a die grinder and cutting two notches into the old hubs. Pipe wrench on the pulley side and a chisel tip on impact hammer. If it works, yeah, three spares on hand. If not well, still learned a lot, a win in my book, cause it was not for a lack of trying.
