village7959
We have a Scag Tiger Cub with 48" deck. Now I know zero turns are known to slide but something just doesn't seem right with ours. Even on flat ground and even blacktop, it will slide pretty bad. At first, I just figured it was normal but just recently, I started mowing for a family member and he has a JD zero turn with a 54" deck, can't recall the model of it. His does not slide hardly at all compared to ours. He has a hillside along the road that is about the same as ours and I would not dare mow ours with the Scag but he is able to do his with no issues. If the scag is on any type of slope and breaks traction, you will be going for a ride no matter how minor the slope is.
Could there be a mechanical issue that would cause the Scag to slide worse? I have the air pressure in the back tires lowered. I think his is wider which I would imagine would help out. But I think the scag has bigger tires, which not sure would help or hurt. Both mowers have turf tires. Are there certain brands that are notorious for this and is Scag one of them?
