kennethburch
- Dec 22, 2018
- 1
- 3
Has anyone found a way to drain the transmission oil without removing it?
The Z5000 does not have filters or drain plugs like this mower in the youtube video
don't listen to anybody that tells you you cannot work on that transaxle. Tuff Torq has a manual on how to fix them. The easiest and fastest way to work on them is to take them out as a unit with the tires on. Should be six or seven bolts total then the brake line. Then roll it out as a unit. Easy, took me less than 20 minutes.
Item number 54 shows a filter kit. I don't know if this is your exact model.
https://www.google.com/search?q=tor...AUIDygC&biw=768&bih=387#imgrc=iEMwmyoFi5YYSM:
