i bought a toro zero turn this summer and was using it when after going forward in a tight spot then reverse to get out as i went to turn the mover quit going forward or in reverse . i found a belt up under the motor that was off and put it back on as it looked like it went but it still doesnot move and smells like the belt is burning after i cpl of min trying to get it to move. whats wrong with it is it something i can fix or i have to take to a shop the manual does not list even that belt i found at all .oh and the blades engage just fine and is on a different belt all to gather .
