Dreaded
 - Dec 18, 2022
- Threads
 - 1
 - 16
From your statement. You said exaust smells rich. That indicates to rich of a air/fuel mixture caused by carburetor misadjusted or need cleaning.The carburetor could just need a good cleaning, if the air ports that control the air fuel mixture is clogged they will cause it to run rich because it will draw more fuel than air. I do not think the valves would cause this though after that long of use they need adjusting.
You stated it ran smooth and I take it to mean no loss of power. You also could have a problem with a mechanical issue that is loading the engine and lowering the rpm that would cause the mowers governor to open throttle more to maintain rpm. This could be as simple as a belt idler bearing making it harder for the engine to maintain rpm. So this problem can be caused by a lot of things.
As DeadmanRoss316 said start with the easiest and work your way through it then if you don't find the problem go back and check everything again. It is easy to miss some simple thing that is causing the problem.
