z225 starts and stops plus fuel leak
snuf6038
Mower was running fine then died from broke wire. Now gas tank drains empty, fuel ran out of sparkplug hole when removed plug. will start run a 3 or 5 seconds then dies. Gas tank has no leak. no viseable fuel line leakage. Any help to solution greatly appreciated. Also engine emmit white smoke when running these few seconds.
mechanic mark
check compression with gauge, possible blown head gasket & may need new piston rings.
absolutely correct, carburetor. i would overhaul carburetor with new kit, post engine manufacturer & all numbers from engine, change oil & filter after installing new carburetor to engine. give it a go & let us know how it goes.
http://manuals.deere.com/cceomview/OMM154566_A7/Output/Index.html
https://www.jackssmallengines.com/j...07-0123-e1/carburetor-kit-carburetor-overhaul
see items 121, 121A, 125A be sure to check code date before purchasing
snuf6038
Thanks Mark, Also fuel in the oil also. Could this be from a bad fuel solenoid or carb. needle sticking?
