Z.t. 1 blade cuts wont doesnt
Scolabird
Hello all newbie here!
I mow our 2 acres with a toro timecutter 42 and no trouble for 3 years. I mow for half hour then let her rest an hour while weedeating... then mow the rest. Ended up hitting a stump and bent the deck and broke blades off the not deck!!
On a budget beat the deck straight removed the blades and spindles and welded it back true to shape. Upon replacing blades it appears only 1 is mowing while the other isnt???? Not certain of the inter workings of z.ts but since the clutch works and one blade mows could it just be one seized spindle?? The mower does run rough now and dies sporadically!
Any help appreciated thanks!
John
