hi 'yall . have a yth22v46 that threw/destroyed it's belt and now seems like pulleys are out of line? but i dont know the specs when they where new. whether they are all supposed to be in the same plane, horizontally speaking. obviously they should probably all be level with one another and two are no longer, but it also seems two are at different heights? that would not have been because of the incident but it makes little sense unless the belt does not ride in the center of each pulley.
but primarily, the 3rd pulley from the left, which is also the highest is the most out of level/bent but the orange welded bracket seems fine. how could that strong bracket have bent ? any ideas ?
