Hello all
I have a YTA24V48 - Somehow the link that bolts to the frame to keep the clutch from spinning upon blade engagement keeps snapping. Mind you, its a 5/16" steel link (Item 197), pretty heavy duty.
It will run, then somehow it gets snapped, the clutch then is free to spin and rips the wires. This is the 4th pin I've replaced. Clutch works fine, its spinning freely when 12V Applied. I just cannot figure out how its getting broken.
You can see the top slot getting abused. What could possible cause the clutch to keep slamming into this pin and snap it.
I have notice the mower does rev up and down occasionally , but if the clutch is working then I don't see how that could affect it. Its driving me nuts!!
