estandridge
Kees 22 hp 61 inch zero turn will not start. Turns over fine turning the key but no spark to the plugs. Was running great, turned a corner, it backfires and went dead, now will not start. Suggestions?
I have now cleaned relays and have spark at the plugs and gas, but the compression is only 28-30 in both cylinders. Does that mean I have valve problems?
