Generac and Stratton
- Sep 3, 2019
- 33
Hello. Bought one of these locally and despite being from, I'm guessing the mid 1970's, it's super tough and breaks up 8" chunks of clay and whatever else I throw at it. A 2' pile of chunks of clay/soil and it just rips.
Anyhow, started popping the belt and noticed the shaft the V pulley is attached to had a lot of end-play. Pulled everything apart, and it has a bearing on the pulley side, but appears to have had some type of thrust collar on the opposite end of the shaft that exits out the opposite chain cover. Very little of the collar left and the shaft is basically sitting loose inside a tube. Tried searching images and schematics and can NOT find this rototiller anywhere. Closest thing I could find was schematics for a model that came later on.
https://www.partswarehouse.com/MTD-TMO-39029-Tiller-s/250895.htm
IF looking at the exploded view of the "Chain Case", mine does NOT have 2 shafts for the V pulley and smallest chain drive sprocket (#38). They are instead on the same shaft. The pulley-side of the shaft, has same/similar #5, #6, and #7. Might even be the same #6 bearing. However, it does NOT have #28, #10, #11, and #5 bearing. It has what I think might have been a #30.
So, to reiterate, my V-pulley is on same shaft as the #38 sprocket (my chain case ONLY has 2 chains) but instead of having a #5 bearing, it has what appears to be (whats left of it is just the rim so guessing at this point) a #30. Am I right in assuming this would be some sort of thrust collar? Can't believe they'd go that route instead of a bearing.
Limited on time, but trying to think of repair options. If I take a very small gauge steel, wrap it around the shaft and stick a washer on the end, and applied liberal amount of axle grease, would that suffice? Also, if ANYONE knows the model number for the "Yardman 3hp 18" Chain Drive" I'd appreciate it. Ink is long faded on the sticker. Unit is torn apart atm so no pics. Also, it doesn't appear to be a 5010 unless it's a later model. Engine pulley is on same side (left side if standing behind rototiller) as the drive pulley on the chain case. Pull start on right side.
