jdefonseka
- May 5, 2014
- 4
- 7
Hello
I have a Yard Machines Model# 3AF608G062.
The Symptoms
The unit has extreme difficulty going from forward/Neutral/ Reverse.
Specially if the mower is at an incline/ decline it's almost impossible to get it out of Forward or Reverse.
I also turn down the throttle completely when trying to move from Forward to reverse or back words.
This is more pronounced when the mower has been used for a little while.
Also when this is happening, the brake lever does not want to stop the mower.
Any ideas as to what might be going on?
I replaced all the belts last year. Not sure if they were OEM belts but it got fresh ones.
The Symptoms
