MikeQBF
[Searched the forum for comments/critiques about the LT42e and didn't find anything, so pardon any duplication from this forum noob.]
The hydro trans on my Craftsman/Husqvarna 42" shot craps a couple of weeks ago and the cost of repairing was far more than it was worth, so I bit the bullet and bought the only reasonable electric lawn tractor on the market, the CC LX1 LT42e. Reasonable, that is, in size and function... certainly not reasonable in price relative to the same thing with a gas engine! But like my sig says, I'm committing to electric lawn maintenance when each tool comes up for replacement. Bought an EGO 21" pusher this past spring and like the heck out of it - quiet, great cut, bags nicely, so I'm a convert.
I have a little over an acre to mow; flat with five trees and four buildings to navigate around. The lawn itself is a mongrel (long story) and very uneven. Rains this summer have made for big challenges keeping it under control.
The CC is a damnsight easier to maneuver than the Craftsman was, and my shoulders are very thankful for it! The LT42e's cut is a lot more even than the old machine, although after today's mow I think I have it set too low, now finally noticing some scalping from bouncing around in the less-smooth areas. The ride is a little rougher than I am used to, but tolerable. The controls are not very refined. Getting it going is like patting your head and rubbing your tummy, while chewing gum. Once you've recited the Hail Marys and have the blades going it's fine. I curse the LCD display for its lack of backlighting - there is sometimes critical information you need to know after being scolded by a warning beep, and unless you are in full daylight you just can't read the display. "Fuel" (battery) gauge is a whopping four LEDs; if the LCD was readable you could read its bar graph to a percentage of charge left, but you're only given that information on power-up.
Charging is also a fraught process. I was firmly advised by the dealer tech to plug in the charging cable before plugging in the (separate) charger to 110V, reversing that process on removing from charging. (I happen to be familiar with the brand of charger they use - DeltaQ - and know the hard way that not following those instructions can result in bad things.) Charger gets very hot, so be careful where you put it; this is also a concern because my other electric appliance with a DeltaQ charger tends to need a replacement every three years or so, and "hot" means wear-and-tear. Haven't had a chance to fully verify that it can do the entire acre on a single charge, but so far I think it can with plenty to spare. It's supposed to go from "empty" to fully-charged in 4-6 hours, and so far I have no reason to doubt that.
It's silent, or nearly so, until engaging the blades. Then it's almost as noisy as any normal gasoline version, although it's not loud enough to send me running for the hearing protectors that I absolutely had to use with the Craftsman and its 18HP one-banger.
Despite the nitpicks I am enjoying the LT42e.
In full disclosure, I am having a problem where it complains about an overheated deck (blade) motor after about a half-hour of operation. Shutting it down for 10 minutes to cool gives another 10 of mowing, and then the same warning appears. I'm going to ask the dealer about this on Monday, but I think I know the answer already - cut height set too low and it's straining on the deep cut. If it was a gasser you'd know this immediately from the engine bogging down; in the case of a modern electric drive the computer's priority is to maintain blade speed, so it supplies more power than it really should for long periods, heating things up accordingly.
