vv0350
I mow a 2 1/2 acre lot in the country. and just bought a XT1, Lt42. I have to back up maybe 20 times per mowing...
I realized that once the safety switch was activated, you could go ahead an mow forward and reverse without any further switch use...BUT if you hit a bump, and we have many, or got off the mower, it would disconnect nd you had to set it again......
SOOOOO, I looked around and followed a set of wires from the back of the "interlock switch", a plunger switch at the back of the reverse rod located under the seat ...I realized there was a easy disconnect plug up under ant at the back of the battery area...secured very near the back of the mower. I pulled the battery out and reached down....squeezed the center of the clear plastic plug, pulled a little on both ends, and it disconnected....tucked the two halved around the other wiring in the area and used a little black tape to double secure everything...The plastic cooling blades are just a few inches away and you would NOT want to have the plug halves get pulled into those blades....Anyway, I put the battery back in and started it up..NOW, when you start the mower, you can push the forward pedal and go forward, then push the reverse pedal and go backward without moving the key, or pushing any button, or waiting for a little light to go on...
NOTE: I have no little kids anywhere near me when mowing...If I did, I probably would not do this modification...
