X520pto
Remove deck & check plug in wire harness at clutch having power 12v. with test light or multimeter. If you have power check 3 windows in clutch itself with feeler gauge .012-.015 , specs. should be in your Operators Manual. Let us know how it goes, thanks, Mark
I use CRC Electronic Cleaner for all electrical harness plugs, switches, etc. & Dielectric Grease before reconnecting.
