Thanks for the advice and your post was a good reminder for me to update the status of this issue. The problem has now been resolved by JD. They related they found the linkage loose, the governor misadjusted, and the pedal mechanism loose. They didn;t state if the bushing were cracked or not. I looked at them recently and they don't appear warn, so maybe they did. This was all repaired without charge since it was apparently not done correctly after they had replaced the engine crankshaft and PTO clutch a couple months ago. The PTO repair was the second one, the first having occured in December (yes, we mow here in DEC! ;-) ) The securing bolt broke right at the thread ends and the blade drive pulley and clutch half fell off. The first repair was to merely put in a new bolt. That lasted about 5 months and it was still under warranty. The next time, it was out of warranty, and after the initial $2000 repair bill, then the 'let's split it' repair bill, then the 'would you pay $600' repair bill, JD finally wrote the whole thing off as we kept insisting that the issue was a design flaw, or was still under the original under warranty repair, or they should have replaced the crankshaft the first time. Eventually, they concurred, and have since been quite accomodating. Mower speed is back to 5.8 MPH (we've measure it) and the cutting is level and height settings now correct as the mower deck had been mal-adjusted also during the PTO repair. So, now all good again. Also, the backfiring issure that had begun occuring around the same time was traced to a bent choke control rod that didn't let the choke fully open when the control handle was released. Choke butterfly was still about 30 degrees open. No more backfiring since that was corrected. :smile:
