X300 has slowed down
JDH12
Last year when I got my x300 back from the dealer, it ran real slow (travel speed). So I checked the position of the bolt on the arm under the right foot pad and they had set it too shallow. So I changed it to full leverage and the travel speed was much better. Now the mower has slowed back down, I checked the bolt and the arm still has full travel but the mower travel speed is too slow.
The mower runs beautifully, no transmission slippage or engine issues. Throttle is set at full on as it always has been, engine sounds the same as always. Travel speed is just too slow. Seems like I need to make another similar adjustment as I did before but I can't figure out where that adjustment might be. Does anyone have suggestions of what I might look at?
How many hours on the machine ?
Do you tow?
have a lot of hills ?
Does the tranny growl ?
MParr
Have you ever done a fluid change on the transmission?
