basstracker
- Jul 9, 2013
- 19
- 51
if you pull the oil stick out with engine running should it blow out where you put oil in?
You should not take the dipstick out when the engine is running. You should not open any fill cap or take out the dipstick of any engine when the engine is running. If you want to check the oil of any engine, its always a good idea to turn the engine off and let the engine sit for awhile to let the oil run down from the top parts of the engine before pulling out the dipstick to get a accurate reading of the oil level.
