yellowdog5
- Jun 1, 2014
- 1
- 2
The problem started when one of the bolts mounting the carburetor assembly came loose from the engine. I replaced the bolt, and tightened everything up I could find that was loose, but it still wouldn't run to full capacity. I have now replaced the air filter, the governor spring, the gasket between the air filter and the carburetor, the fuel line and the spark plug. It usually won't prime, I have to do that manually, and when I do get it running it surges (fluctuates). Even when warmed up it needs to be manually primed. Any suggestions? It's a 6 1/2 horse quantum edge (123K02-0132-E1)
