Automatic compression release. It is common for the decompressor parts to break and end up in the oil pan. Preventing the engine from properly spun over to start.Sorry what does ACR stand for, I set valve leak at. 004 for intake and. 007 for exhaust what skills they be at?
Thanks for all the help CyAutomatic compression release. It is common for the decompressor parts to break and end up in the oil pan. Preventing the engine from properly spun over to start.
The clearances for the valves are .004-.006 for intake keeping in mind that the intake is the bottom valve in the head. And the exhaust is .005-.007
I got it thank you allremove the spark plug(s) and see if anything changes. That will tell you if it is the ACR, mechanical like a hung valve, or hydro-locked. Watch for fuel puking out the plug hole(s).
