Won't stay running
Muldrick
I have a Sears push mower with a 5.5 or 6hp engine.
It would only run if I continued pushing the fuel bubble or sprayed carb cleaner into the carb.
Ok, easy enough, clean the carb out should fix it, obviously a fuel restriction.
Cleaned the carb, jets, needle and seat, etc. Does the same thing!:mad:
I then replaced the carb and it STILL doe the same thing....makes no sense. :mad:
I had already replaced the fuel and filter.
Does anyone have any ideas what the problem might be?:confused2:
SeniorCitizen
First leg of the fuel's trip is from the tank to the filter. Consider checking that even though the primer says it is.
platefire
I worked on a friends Honda this week and cleaned his corroded carb. When I put the carb back on it ran a minute and died. I double checked and no gas coming out of fuel line to carb. I found the fuel filter was on backwards and once I reversed it everything was flowing like it should and staying running. Bob
Muldrick
If I pull the fuel line off the carb, fuel poors out, so there certainly seems to be no delivery problem
Scrubcadet10
Moderator
Staff member
could it be a cracked intake manifold/tube causing a vacuum leak?
