won't start
hankmontgo
I can't get my cub cadet to start no click no nothing; replaced solinode ' checked fuse and starter all is good, just won't do anything.
Are you sure that battery is good, After that then you will need to check/test the pto switch, and the brake/clutch switch. Also make sure the battery terminals are clean and tight on both ends. Also check the connection for the negative cable were it connects to the frame for corrosion.
