won't start, won't fire
Narko
Have a B and S 143 424152 on a Sears push mower. Won't start won't fire. Sometimes kicks back sometimes as tho it is firing prematurely (well before TDC) . Any ideas?
Sheared flywheel key would most likely be the cause.
Tinkerer200
Yeah and it doesn't take much on push mower. BIL scoffed at me when I showed him a barley marked key telling him that was his problem. Jaw dropped when I installed new key and it started right up. (And I grinned with satisfaction)
Walt Conner
Romore
The model number indicates a Tecumseh, not a Briggs. Check the hub and blade as well, if not tight the same thing will occur.
Narko
Yes, it WAS a sheared flywheel key. Thanks Folks. Went to my diecast bucket and found a used one which in put in with the help of a neighbor. Will start and run now just don't have the linkage hooked up right so isn't running as should. Can any one post a pic. In meantime i'll see what I can find on YouTube.
Was not able to find something that specific on YouTube.
Seem to have throttle and governor linkage hooked up properly now and all parts back on. Torqued flywheel nut to 40 ft lb. Does this sound right? It had loosened up after first successful start up. Tomorrow gas in tank and cut-grass test.
