victoriffic
I have a 2007 Scag Wildcat, which has been a perfect piece of equipment untill now. After sitting in the barn all winter, the original battery was dead. I jump started the engine (26 hp Kaw ) and it started right up. When I disconnected the jumper cables it died......after that it will not crank nor is their any spark when I jump across the starter with the key on.
All the interlocks check good, I found a diode on the wiring diagram and finally found it buried in the wiring harness, it test good. The starter relay is good and I even swaped it with another to verify this.
Grass is 12" tall......Help
