1.Typically a 30 minute run then nothing is trash/bugs/grass/leaves in the fuel tank. Waiting say 30 mins and she starts fine as the OP described is it. Flush all tanks out and blow with shop air. Probably not a bad idea to install new fuel line from tank to carb. New filter and shutoff too.
2.Pull the fuel line off AT the carb inlet. Drain into a clear jar. Look for water and poor delivery. Should have a solid stream if the tank is clear.
3.Could be a fuel cap non venting issue. Shot in the dark. Whiling draining leave the cap ON and tight. If you crack the cap and the fuel delivery improves, your cap is not venting.
4.Another long shot is a weak sparky coil getting hot.
5.Last is trash/bugs/leaves in your fuel can. Do you have a wide open spout on your fuel can? Or a new style spout that are basically sealed? If yours is open, every time you fill up you pass garbage to the carb. Make sure your can and tank/s are clean.
