Won't crank over
Jerman
My John Deere 170 ran fine. My son got done mowing and shut the mower off. Now it won't crank over. Has a new battery. If you flip the PTO switch up and turn the key you can hear the clutch underneath click. Disengage the PTO switch and turn the key nothing happens at all. Any ideas?
mechanic mark
check seat switch as well as all connections by hand making sure everything is tight & secure.
