oldgrasscutter
- Oct 9, 2012
- 2
- 11
I was given a old Wizard riding mower with a 6 forward speed 1 reverse transmission. The model is unknown because the plate with the model # is long gone.
The problem is in the transmission. Without the engine running it will shift to any gear back and forth with no problems at all. With the engine running it is next to impossible to shift to any gear. You can jam it in gear with the clutch depressed but cannot shift to another gear until you shut the engine off. I have adjusted the linkage and the idler pulley is fully disengaged with the clutch pedal depressed. Anyone with any thoughts. I have to believe it's got something to do with the adjustment of the linkage. Thanks, Oldgrasscutter.
